Exclude certain html tags from calais processing
I am using tagging API using URL "https://api.thomsonreuters.com/permid/calais". I pass HTML content to the API for processing. I want to exclude certain parts of the HTML from being processed. For example, tags with class "robots-nocontent" or hidden elements or by specifying something else on the tag.
How can I achieve this?
intelligent-tagging-apiintelligent-taggingopen-calais-apisemantic-metadata-tagging
HTML content can be tagged using the following header: Content-Type: text/html
If there are sections that you wish not to tag, you can remove them prior to submitting the API request.
