What is the best way to maintain websocket connection?
I am trying to publish data to Elektron's websocket. Authorization token only lives for 10 minutes and when it expires, session is being closed. Before session expires I would like to start new session using refresh token. Once new session is ready my system would switch over to it and close previous session.
With this approach i am experiencing a bit inconsistent behaviour from the system. Sometimes when I issue login request for second session - first one gets closed.
I am attaching diagram of experienced behaviour.
I would appreciate any hints on how can I maintain websocket in such way so my system always have at least one active connection to publish data.
Regards,
Jan Roman
websockets
Ok, in that case, you don't need to start a new websocket session. When the auth token is about to expire, you can proactively renew a new token and send it to the server. This way your existing connection will not be terminated.
See the python tutorial and associated example here.
Hello @jan01,
Can you please elaborate on how you are trying to publish the data. Are you using Refinitiv Contributions Channel?
Hi Gurpeet,
Thanks for getting back. Yeah I am using Refinitiv Contributions Channel using websocket connection to your cloud instance. For now I am using preproduction environment at endpoint: wss://contrib-ws1-emea1.uat.platform.refinitiv.com/WebSocket
I am using OAuth endpoint: https://api.ppe.refinitiv.com/auth/oauth2/v1/token
Regards,
Jan
