how can I retrieve sedol from isin using eikon data api
eikon-data-api
Hi @vishal.kak ,
Ideally you can use the symbology call in the Eikon Aata API to get the symbol conversion. E.g:
ek.get_symbology(
    ['US5949181045', 'US02079K1079', 'US4592001014'],
    from_symbol_type='ISIN',
    to_symbol_type='RIC')
However, this might not work when using ISIN as a source, since there is a one to many mapping, and no best match.
I would recommend that you speak with Eikon content experts at my.refinitiv.com to see if there is another means to do this.
Update: You can use the get_data call to get the SEDOL using this call:
Thanks for your response
Why am I getting "No best match available" error when I try to search for Microsft ISIN - US5949181045
df = ek.get_symbology("US5949181045", from_symbol_type="ISIN", to_symbol_type="SEDOL")
I edited the previous answer. Try to use the get_data call instead.
perfect, that worked - thanks
