Unable to query Symbology Changes using DataScope Select API
I'm trying to generate a symbology change report using DataScope Select API, however it is unable to process many Ric Roots.
Example 1: Symbology Change for FW20 using continuous RIC
Input
URL: https://selectapi.datascope.refinitiv.com/RestApi/v1/Extractions/ExtractRaw (POST)
  "ExtractionRequest": {
    "@odata.type": "#DataScope.Select.Api.Extractions.ExtractionRequests.TickHistoryTimeAndSalesExtractionRequest",
    "ContentFieldNames": [
      "Symbology Change - Change Type",
      "Symbology Change - New Value",
      "Symbology Change - Old Value"
    "IdentifierList": {
      "@odata.type": "#DataScope.Select.Api.Extractions.ExtractionRequests.InstrumentIdentifierList",
      "InstrumentIdentifiers": [
          "Identifier": "FW20c1",
          "IdentifierType": "Ric"
    "Condition": {
      "MessageTimeStampIn": "GmtUtc",
      "ApplyCorrectionsAndCancellations": "false",
      "ReportDateRangeType": "Range",
      "QueryStartDate": "1996-01-01T00:00:00.000Z",
      "QueryEndDate": "2021-11-23T12:59:59.000Z",
      "DateRangeTimeZone": "Local Exchange Time Zone",
      "DisplaySourceRIC": "true"
Output
  "@odata.context": "https://selectapi.datascope.refinitiv.com/RestApi/v1/$metadata#RawExtractionResults/$entity",
  "JobId": "0x07ccb58680fd568a",
  "Notes": [
    "All identifiers were invalid.  No extraction performed."
  "IdentifierValidationErrors": [
      "Identifier": {
        "@odata.type": "#DataScope.Select.Api.Content.InstrumentIdentifier",
        "IdentifierType": "Ric",
        "Source": ""
      "Message": "Not found"
Observation
Continuous Ric is considered invalid by the API but this works on the GUI while querying in Historical section
Example 2: Symbology Change for FW20 after expanding RIC chain
Input
    "IdentifierList": {
          "Identifier": "FW20H11",
          "Identifier": "FW20M11",
          "Identifier": "FW20U11",
          "Identifier": "FW20Z11",
    "Condition": {
Output
  "JobId": "0x07ccae777b1d566f",
  "Notes": [
      "Identifier": {
        "Source": ""
      "Identifier": {
        "Source": ""
      "Identifier": {
        "Source": ""
      "Identifier": {
        "Source": ""
Observation
Constituent Rics are considered invalid by the API but this works on the GUI while querying in Historical section
This is the case for many more Ric Roots such as NG, DOL, IND, LCO etc. It does work for some Ric Roots such as JYc1, but I can't figure out why. Please advise.
pythondatascope-selecthistoricalsymbologyric
@abhinav.mathur
You may need to set AllowHistoricalInstruments to true, as shown below.
 "IdentifierList": {
      ],"ValidationOptions":{"AllowHistoricalInstruments": true}
Thanks this worked perfectly
