Source Directory Update message processing by EMA Consumer application
We are writing a consumer application to connect to TREP:
  1. When a Source Directory Update message is received indicating AcceptingRequests=No, what should be done by the application when it needs to create a new item stream? (Should the application search for another service that provides the same Capabilities and use that service to send new item requests?)
  2. When a Source Directory Update message is received indicating Status = None, according to EMA30_RDMUsageGuideAPI fan out it to Status message for each item stream? Suppose we are using a service related to MarketPrice domain. Then does this mean, the application receives MarketPrice Status messages for each item stream that have been opened. If so, what will be the DataState and StreamState of each Status message received by the application?
elektronrefinitiv-realtimeelektron-sdk
7.6k 15 6 9
@kelvinyoung048
For #1
I think your understanding is correct. From section 4.4.2 ServiceState and AcceptingRequests If the servicestate is up but acceptingRequests is No. The immediate provider is not accepting new requests. However reissue requests on already open streams can be processed. In this case you want to send a new item requests(not reissue), so you need to find another service that provide the capability you want to request and the new service must have ServiceState=Up and AcceptingRequests=Yes.
For #2
As far as I understand,for the publisher/provider such as UPA/ETA provider, sending Status with directory is equivalent to sending an RsslStatusMsg to each item. This status only applies to item streams that have received a refresh or status of stream state OPEN with data state OK(OPEN/OK). I think None in the Status is the status code inside Status object. Therefore EMA Consumer should receive stream state Open and Data state OK.
