How do I convert a DSGRID/DataStream query into one for the Python API?
I am trying to pull in Options pricing data. I already have the relevant input codes - here is the query I used to use in DataStream with DSGRID
=@DSGRID($D$2:$H$2,"O3",$C$1,"","D","SDateCellRef=true;ColHeader=true;DispSeriesDescription=false;YearlyTSFormat=false;QuarterlyTSFormat=false;AutoRefresh=false","")
where $D$2:$H$2 is
MSQ$DELTA25C MSQ$DELTA25P MSQ$DELTA10C MSQ$DELTA10P MSQ$DELTAATM
and $C$1 is a date, say, 1/1/2015.
I am now trying to pull this using the Python API // in codebook. Can somebody help?
eikon-data-apidatastream
@Nikunj.Jain
The code looks like the following.
ds.get_data(tickers='MSQ$DELTA25C,MSQ$DELTA25P,MSQ$DELTA10C,MSQ$DELTA10P,MSQ$DELTAATM',
            fields=['O3'],
            start='2015-01-01',
            freq='D')
The output is:
1.4k 6 2 2
Hi @Nikunj.Jain ,
There are example Notebooks showing how one may use Datastream in Codebook:
Then under 01. Data Retrieval & Discovery
and then 01.03.Datastream Library
Please do let me know if those examples are enough
