Where can I download an older version of the RFA Java API?
I would like to download RFA Java 8.1.3.L1 but I don't see listed in the Latest Version or https://developers.refinitiv.com/en/api-catalog/refinitiv-real-time/robust-foundation-api-rfa-java/downloads#rfa-java-latest-version or in the https://developers.refinitiv.com/en/api-catalog/refinitiv-real-time/robust-foundation-api-rfa-java/downloads#rfa-java-older-versions. Where can I find it?
rfa-apiDownload
9.7k 49 38 60
Hi @joshua.phillips
Older versions, such as 8.1.x were replaced with newly branded versions Is there any reason why you can't use a more recent version? As outlined within the Overview page, this is the position as stated by the product team:
IMPORTANT Rebranding Annoucement: Starting with version RFA Java 8.2 and 7.7, there are namespace changes to the ValueAdd libraries. Please note that all interfaces remain the same as prior releases of RFA and will remain fully wire compatible. Along with RFA packages and in the same location as release notes, a REBRAND text file is available which details impact to existing applications, if ANY, and how to quickly adapt to the re-branded libraries. Existing applications will continue to work indefinitely as-is. Applications should be proactively rebranded to be able to pick up fixes or support for new compilers and operating systems, available post rebranding release. For more details on support, refer to PCN .
