Index Constituents of delayed RIC (Russel 3000)
Hi, i have a delayed access to Russel 3000 index constituents (Do not have permission to get with "TR.IndexConstituentRIC") , so i get the data in excel with this formula -> =TR("0#.RUA","", "SKIP:1-1")
How can i get this with python?
eikonpython
1.7k 2 4 7
@elie ,
This seems to be a permission issue, could you please try to print an error returned from get_data function using the code below to confirm this assumption?
df, err = ek.get_data(["0#.RUA"],['DSPLY_NAME'])
print(err)
In case an error returned mentioned that you don't have permission, you can contact Refinitiv Content Helpdesk, which can be reached using any method below
@elie
I can use the following code to retrieve Russel 3000 index constituents.
df
The output is:
Doesn't work for me, I get NaN
