how to use Plotly.io on CODEBK?
Please assist me how to save the chart as image file, like png, which is created by plotly.
I would like to save the image just like matplotlib.pyplot.savefig()" without clicking "Download" button on the chart with plotly.
Thanks in advance.
codebook
11.5k 16 7 10
Hello @mika
According to the Static Image Export in Plotly Python document, you need either Kaleido or orca libraries to save the Plotly chart/figure to an image file. Unfortunately, the Codebook is the control-hosted cloud-based environment that you cannot install additional libraries.
You can find the list of the supported libraries in the "Libraries&Extensions.md" file in the Codebook workbench.
Please note that you can save the figure to the HTML file with the following code in the Codebook.
plotly.offline.plot(fig, filename='chart.html')
Hi wasin,
thank you for your answer, well noted.
I will try to use jupyter instead, otherwise will use matplotlib.pyplot, becuase the request is insert the image on Excel sheet by Python.
kind regards,
Mika
