Error code 500 | Server Error: Internal Server Error on Eikon Data API
We got an issue with romualdo.padovano@totsa.com.
He got this error :
Error code 500 | Server Error: {"code":500,"message":"getaddrinfo ENOTFOUND apac1.apps.cp.thomsonreuters.com apac1.apps.cp.thomsonreuters.com:443","statusMessage":"Internal Server Error"}
It seems we already have this kind of error in the past.
Please check the case: 10348085 .
Could you please do the same?
Many Thanks,
Best Regards,
eikoneikon-data-apipython
23k 22 9 14
Hello @oualid.mahiouz and all,
From the case resolution, the issue as reported was resolved by adding configuration to Eikon user account on our side.
9.7k 49 38 60
Hi @oualid.mahiouz
Can you please provide the version of the Eikon Data Library you are using and the code snippet that is resulting in the error.
