Refinitiv Real-Time Managed Distribution Service instrument limit
Hello!
I have several questions about "instrument limit":
1) How does this limit counted? I mean, if I have the limit of 1000 instruments, does it mean that I can subscribe to the Market Price domain for 1000 symbols?
If I need both MBP and MP domains, I can subscribe only for 500 instruments?
2) What is an expected behavior when I am trying to register a new OmmConsumer which exceeds this limit?
api-limits
Hi @Nikita
Can I assume you are referring to the ADS config parameter:
itemLimit : Sets the maximum number of allowable open items per user per service.
OR
aggregateItemLimit:Sets the maximum number of allowable open items per user for all services
I would expect the limit to be in relation to the total number of open streams/items at any given point in time. As an MBP stream and MP stream for the RIC would represent two streams I would expect it to count as 2 towards your limits - so you would be limited to 500 MPB and 500 MP for example.
In terms of exceeding the limit, I would expect you to receive a Status Message with a Closed Stream state and a Status code such as TOO_MANY_ITEMS.
More likely you would see something like the following:
'A20: Aggregate item limit exceeded.'" - Forum | Refinitiv Developer Community
Thanks for the help!
