List of available parameters for IPA API in Python
Hi there, I was wondering if there was a list of available input parameters for IPA API in Python, similar to these:
calculation_params = bond.CalculationParams(
market_data_date="2020-07-05",
price_side = ipa.enum_types.PriceSide.BID,
most of the time, I can add underscore between words to make it work, but for parameters such as 'reportCcy', it won't work in Python.
reportCcyStringThe reporting currency code, expressed in ISO 4217 alphabetical format (e.g., ' USD'). It is usually set to express the amounts for the fields that end with ' xxxInReportCcy'.OptionalThe default value is notional currency.Pricing Analysis
ipardp
Hi @thomas.j.tan ,
I understand that you are using refinitiv-dataplatform Python package. Please let me know if it's not the case. Below answer is related to that package.
There are several ways to get list of supported parameters:
- Use automatic code completion in your IDE. See example: code-completion.png
- Go to class definition in your IDE. See example:go-to-definition.png
- Open following file and all parameters will be listed there - %Your_Python_Folder%\Lib\site-packages\refinitiv\dataplatform\content\ipa\contracts\bond\_bond_pricing_parameters.py
For reference: full list of parameters supported by API can be found at API Playground > "/data/quantitative-analytics/v1/financial-contracts" > Swagger. However you may need to query API directly to use some of them. Not all parameters may be supported by mentioned Python package.
Let me know if you have any other questions.
Thanks,
Mark
Hi @thomas.j.tan
Does the following work for you?
        report_ccy = "USD"
I am trying to find a complete list for your reference.
Hi @thomas.j.tan
Note that the API Playground parameters may use different case e.g. camelCase whereas the RDP Python Library uses conventional python snake_case for the parameter names e.g.
  • API Playground: reportCCy
  • RDP python Library: report_ccy
