limit of PermID - Record Matching - RESTful API
Hi there, I saw the limit of the permID api is 5000 daily in the API documentation: https://developers.refinitiv.com/en/api-catalog/open-perm-id/permid-record-matching-restful-api/documentation.. However, the API still works when the total daily input exceeds 5000. is the documentation out of date? what the real daily limit? please confirm, thank you so much!
permid-api
@pengxin1211
I will contact the PermID support team to verify the limitation.
@pengxin1211
The total daily quota is 5000 requests per day per API key. This quota has been reset at 00:00 GMT.
It could be the count was spread over 00:00 GMT that allowed to access more than 5000 requests because of the quota reset.
