Content Length Header already present
The url i'm using is: https://api-worldcheck.refinitiv.com/v2/cases/screeningRequest
And my header are:
Content-Type: application/json
Authorization: XXXXXX
Content-Length: 255
And the payload is:
"groupId": "5jb6nlmky7ma1fznxdeemjygm",
"entityType": "INDIVIDUAL",
"caseId": "",
"providerTypes": [
"WATCHLIST"
"name": "{ {issue.summary}}",
"nameTransposition": false,
"secondaryFields": [],
"customFields": []
However I am prompted with "Content Length Header already present" and if I remove this header, I am then prompted with error 401:
Date: Wed, 22 Sep 2021 02:39:17 GMT
Transfer-Encoding: chunked
Connection: keep-alive
Strict-Transport-Security: max-age=15552000, includeSubdomains
Authorization: WWW-Authenticate: Signature realm="World-Check One API",algorithm="hmac-sha256",headers="(request-target) host date content-type content-length"
Any ideas?
world-checkworld-check-onejson-payload
Hi @fjhumka
Please find the sample request:
curl --location --request POST 'https://api-worldcheck.refinitiv.com/v2/cases/screeningRequest' \
--header 'Date: Thu, 23 Sep 2021 07:27:59 GMT' \
--header 'Content-Type: application/json' \
--header 'Authorization: Signature keyId="YOUR API KEY",algorithm="hmac-sha256",headers="(request-target) host date content-type content-length",signature="a3LucKET/dt9cTFc/WE6FVCIvEecxiPq1FsbceM8UgI="' \
--header 'Content-Length: 101' \
--data-raw '{
"groupId": "5jb707er6nj51fj1qcpj7nz4z",
"caseId": "",
"providerTypes": [
"WATCHLIST"
"name": "John Smith",
"customFields": []
Also find the pre-scripts which will help you to generate the signature:
function generateAuthHeader(dataToSign) {
var hash = CryptoJS.HmacSHA256(dataToSign, environment["api-secret"]);
return hash.toString(CryptoJS.enc.Base64);
function isEnvValuePopulated(envVal) {
if (_.isEmpty(pm.environment.get(envVal))) {
pm.environment.set(envVal, "--REQUIRED-VALUE-MISSING--");
return false;
} else {
return true;
isEnvValuePopulated("group-id");
var date = new Date().toGMTString();
var content = request.data;
content = content.replace("{ {group-id}}", environment["group-id"]);
var contentLength = unescape(encodeURIComponent(content)).length;
var dataToSign = "(request-target): post " + environment["gateway-url"] + "cases/screeningRequest\n" +
"host: " + environment["gateway-host"] + "\n" +
"date: " + date + "\n" +
"content-type: " + environment["content"] + "\n" +
"content-length: " + contentLength + "\n" +
content;
var hmac = generateAuthHeader(dataToSign);
var authorisation = "Signature keyId=\"" + environment["api-key"] + "\",algorithm=\"hmac-sha256\",headers=\"(request-target) host date content-type content-length\",signature=\"" + hmac + "\"";
postman.setEnvironmentVariable("authorisation", authorisation);
postman.setEnvironmentVariable("currentDate", date);
postman.setEnvironmentVariable("contentLength", contentLength);
Hi @fjhumka
Are you using the POSTMAN to initiate the API call, if yes, the we would request you to kindly delete the postman collection and environment settings and then re-import the collections & environment. Once done, please try initiating the API call again and let us know if issue persist.
Hi @Vivek Kumar Singh ,
Thank you for your response.
I am actually initiating the API call through a Web Request in JIRA.
I am not too sure about the structure of the Authorization header though:
Signature keyId="XXXXXXXXXXXXXXXXXXX",algorithm="hmac-sha256",headers="(request-target) host date content-type content-length",signature="YYYYYYYYYYYYYYYYYYYYYYYYYYY"
Regards
Thank you very much for your response.
This works fine in Postman.
However I am trying to access WorkCheck One API through JIRA Web Request and I am prompted with the 401 error.
It seems that the "Authorization" header of JIRA is not recognizing the format. Any idea of how to configure this?
Response 401
Headers (5)
Date: Fri, 24 Sep 2021 04:54:55 GMT
Request POST https://api-worldcheck.refinitiv.com/v2/cases/screeningRequest
Headers (2)
Authorization: Signature keyId="XXXXXXX",algorithm="hmac-sha256",headers="(request-target) host date content-type content-length",signature="YYYYY"
Payload
"caseId": "",
"providerTypes": [
"WATCHLIST"
"name": "",
"customFields": []
Regards,
Hi @fjhumka
Can you please help us with the actual Request headers & Response Headers along with the IP address. We need these details to troubleshoot further.
