historical intraday data DSS
How can I extract intraday prices for a past date range through the API?
I am trying to follow the example, but when using PriceHistoryExtractionRequest I get a permission error, however from the GUI I am able to create reports for TickHistoryTimeAndSalesReportTemplate and extract intraday data.
pythondss-rest-apidatascope-selectdss
Hello @giacomo.mazzi,
Do you see Price History report in GUI? If not, then you are only permissioned for TickHistory and not DataScope Select.
Hi @Gurpreet ,
you are right, I have permission only for TickHistory, so my question is, within the GUI I can create a TickHistoryTimeAndSalesReportTemplate for a given date range in the past. How can I do it programmatically through the API?
The closest example I found in the tutorial is the one with Price History (tutorial 4), but trying to modify it to work with the TickHistory template fails, I get a "Invalid array element type for property \'ContentFieldNames\".
