Backend error 'TR.EventType' and 'TR.EventType.date'
Hello, support team.
I'm use EIKON api. this command is error.
import eikon as ek
ek.set_app_id('*************************')
df, err = ek.get_data(['1313.T'], fields=['TR.EventType']) --> Backend error 400
df, err = ek.get_data(['1313.T'], fields=['TR.EventType.date']) --> Backend error 400
df, err = ek.get_data(['1313.T'], fields=['TR.TickerSymbolCode']) --> no problem.
It worked fine until Sep 17th.
Please research this issue.
Best regards,
1.7k 2 4 7
Hi @kengo_takahashi ,
I can run the code you posted without an error. (but using '1313.T', <NA> is returned so I tried with RIC '6501.T' instead and there's the data returned)
Could you please try to restart the Eikon Desktop app and/or your machine and retry running the code again?
If it's still not working, please set the debug log using the code below and copy-pasted the log here then we could do further investigation. Please also remove your credentials (applicationid, authorization) from the message before posting
ek.set_log_level(1)
