Is there a way in RDP Symbology to pull up all security-related mappings (GlobalTickerMap record, Cusip or Sedol, etc.) for Angion Biomedica Corp.?
rdp-apirefinitiv-data-platformsymbology
Hi @Jenna.Tabunda, @Alex Putkov.
In the example query above, this will navigate to all the 'at level' identifiers, so if the input is a RIC, it will return all the quote level identifiers associated with the RIC, if the input was an organisation permID, it would return all the organisation level identifiers like LEI.
In order to go from an organisation level identifier to all the related identifiers at the instrument or quote level associated with that organisation, some relationships need to be specified in the path parameter.
Below are 2 examples:
Navigate from Organization PermID to all instrument level identifiers for instruments issued by Angion Biomedica Corp PermID 5000644263
"from": [
"identifierTypes": [
"PermID"
"values": [
"5000644263"
"to": [
"ANY"
"path": [
"relationshipTypes": [
"InverseIsIssuedBy"
"objectTypes": [
"from": "Organization",
"to": "AnyInstrument"
"type": "strict"
Navigate from Organization PermID to all quote level identifiers for all instruments issued by Angion Biomedica Corp PermID 5000644263
"from": [
"PermID"
"values": [
"5000644263"
"to": [
"ANY"
"path": [
"InverseIsIssuedBy"
"objectTypes": [
"InverseIsQuoteOf"
"objectTypes": [
"from": "AnyInstrument",
"to": "AnyQuote"
"type": "strict"
@Jenna.Tabunda
I'm not sure I understand the question. Are you asking whether symbology lookup endpoint on RDP can be used to retrieve all available identifiers for an entity given one identifier? If this is what you're asking, the answer is yes. There's an example titled "Identifier to all identifiers for the entity" for /discovery/symbology/v1/lookup endpoint on API Playground. And here's the example using ANGN.O RIC.
  "from": [
        "RIC"
      "values": [
        "ANGN.O"
  "to": [
        "ANY"
  "type": "strict"
The result of the above request is
  "data": [
      "input": [
          "value": "ANGN.O",
          "identifierType": "RIC"
      "output": [
          "value": "Q911123844",
          "identifierType": "TMTPermID"
          "value": "@ANGN",
          "identifierType": "DsQuotationMnemonic"
          "value": "ANGN-US,USD,NORM",
          "identifierType": "IlxId"
          "value": "ANGN",
          "identifierType": "ExchangeTicker"
          "value": "488899843",
          "identifierType": "QuotePI"
          "value": "BMD8P43",
          "identifierType": "Sedol"
          "value": "US03476J1079",
          "identifierType": "ExchangeIsin"
          "value": "99325Q",
          "identifierType": "DsQuotationNumber"
  "requestId": "530e5607-30e1-4c8c-8174-863576235bba",
  "effectiveAt": "2021-09-15T19:27:53.944Z",
  "messages": []
Thank you @Alex Putkov.
