How to use RDMFieldDictionary using EMA java API ?
I'm specifying the field ids of fields I'm interested for a list of RICs as below.
OmmArray fieldAarray = EmaFactory.createOmmArray();
   fieldAarray.fixedWidth(2);
   fieldAarray.add(EmaFactory.createOmmArrayEntry().intValue(22)); //BID
   fieldAarray.add(EmaFactory.createOmmArrayEntry().intValue(25)); // ASK
I believe I need to use the RDMFieldDictionary to get the field id of an field instead of hard-coding the same in the code. I'm not able to find any sample code. Can you please point to a sample that demonstrates how to use RDMFieldDictionary using Java EMA api ?
I'm sorry if it is already there and I didn't look properly.
Thanks in advance.
Mani
elektronrefinitiv-realtimeelektron-sdkrrtema-apijava
@Mani.A
You can load the data dictionary from the local files (RDMFieldDictionary and enumtype.def) by using the following code.
        DataDictionary dataDictionary = EmaFactory.createDataDictionary();
        dataDictionary.loadFieldDictionary("RDMFieldDictionary");
        dataDictionary.loadEnumTypeDictionary("enumtype.def");
        System.out.println(dataDictionary.entry("BID").fid());
Those files are available in the <RTSDK_PATH>\Java\etc directory and GitHub.
You can also download the data dictionary from the connected server. For the sample code, please refer to the ex332_Dictionary_Streaming.
Thank you @jirapongse.phuriphanvichai. It worked after I gave relative/full path to the dictionary files.
Is there a way to load these files from CLASSPATH ?
Or even better how can load these from the Dictionary entries specified in the EmaConfig.xml ?
In the EmaConfig.xml
<Dictionary>
   <Name value="Dictionary_2"/>
   <DictionaryType value="DictionaryType::FileDictionary"/>
   <RdmFieldDictionaryFileName value="./etc/RDMFieldDictionary"/>
    <EnumTypeDefFileName value="./etc/enumtype.def"/>
</Dictionary>
Thank you in advance.
Mani
