I am getting below error now in python when i try to use for RTH REST Api:
TimeoutError: [WinError 10060] A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond
Is it related to proxy ? how to provide proxy setting in python in order to do extraction for TRTH REST Api ?
Below is part of the code which is almost same like given in tutorial :
# Imports: import requests import json import shutil import time import urllib3 import gzip # ==================================================================================== # Step 1: token request reqStart = "https://selectapi.datascope.refinitiv.com/RestApi/v1" requestUrl = reqStart + "/Authentication/RequestToken" requestHeaders = { "Prefer": "respond-async", "Content-Type": "application/json" } requestBody = { "Credentials": { "Username": myUsername, "Password": myPassword } } r1 = requests.post(requestUrl, json=requestBody, headers=requestHeaders) if r1.status_code == 200: jsonResponse = json.loads(r1.text.encode('ascii', 'ignore')) token = jsonResponse["value"] print('Authentication token (valid 24 hours):') print(token) else: print('Replace myUserName and myPassword with valid credentials, then repeat the request') # In[7]: # Step 2: send an on demand extraction request using the received token requestUrl = reqStart + '/Extractions/ExtractRaw' requestHeaders = { "Prefer": "respond-async", "Content-Type": "application/json", "Authorization": "token " + token } requestBody = { "ExtractionRequest": { "@odata.type": "#DataScope.Select.Api.Extractions.ExtractionRequests.TickHistoryRawExtractionRequest", "IdentifierList": { "@odata.type": "#DataScope.Select.Api.Extractions.ExtractionRequests.InstrumentIdentifierList", "InstrumentIdentifiers": [{ "Identifier": "CARR.PA", "IdentifierType": "Ric" }] }, "Condition": { "MessageTimeStampIn": "GmtUtc", "ReportDateRangeType": "Range", "QueryStartDate": "2016-09-29T12:00:00.000Z", "QueryEndDate": "2016-09-29T12:10:00.000Z", "ExtractBy": "Ric", "SortBy": "SingleByRic", "DomainCode": "MarketPrice", "DisplaySourceRIC": "true" } } } r2 = requests.post(requestUrl, json=requestBody, headers=requestHeaders) r3 = r2 # Display the HTTP status of the response # Initial response status (after approximately 30 seconds wait) is usually 202 status_code = r2.status_code print("HTTP status of the response: " + str(status_code)) # In[8]: # Step 3: if required, poll the status of the request using the received location URL. # Once the request has completed, retrieve the jobId and extraction notes. # If status is 202, display the location url we received, and will use to poll the status of the extraction request: if status_code == 202: requestUrl = r2.headers["location"] print('Extraction is not complete, we shall poll the location URL:') print(str(requestUrl)) requestHeaders = { "Prefer": "respond-async", "Content-Type": "application/json", "Authorization": "token " + token } # As long as the status of the request is 202, the extraction is not finished; # we must wait, and poll the status until it is no longer 202: while (status_code == 202): print('As we received a 202, we wait 30 seconds, then poll again (until we receive a 200)') time.sleep(30) r3 = requests.get(requestUrl, headers=requestHeaders) status_code = r3.status_code print('HTTP status of the response: ' + str(status_code)) # When the status of the request is 200 the extraction is complete; # we retrieve and display the jobId and the extraction notes (it is recommended to analyse their content)): if status_code == 200: r3Json = json.loads(r3.text.encode('ascii', 'ignore')) jobId = r3Json["JobId"] print('\njobId: ' + jobId + '\n') notes = r3Json["Notes"] print('Extraction notes:\n' + notes[0]) # If instead of a status 200 we receive a different status, there was an error: if status_code != 200: print('An error occured. Try to run this cell again. If it fails, re-run the previous cell.\n')
