Securities' names
Hi, I am trying to retrieve the instrument name (e.g., IBM.N) of all public entities in a country (say, the USA, or Italy, or Germany, ..) using the Eikon package in python. At the moment I am using the get_data function with synatx = SCREEN(U(IN(Equity(active,public,primary))), IN(TR.ExchangeMarketIdCode,"<list of exchanges>"))'. However, I am not able to pull all the securities this way. Is there a more efficient method to do so?
1.7k 2 4 7
Hi @sc11214 ,
You may check this article Find Your Right Companies with SCREENER | Eikon Data APIs(Python)
Below is an another example of the conversion from Eikon Excel formula to Python script
I've got this Excel formula from Screener app
=@TR("SCREEN(U(IN(Equity(active,public,primary))/*UNV:Public*/), IN(TR.ExchangeCountryCode,""BN"",""KH"",""ID"",""LA"",""MY"",""MM"",""PH"",""SG"",""TH""), CURN=USD)","TR.CommonName;TR.ExchangeCountry","curn=USD RH=In CH=Fd")
which can be converted to this Python script
syntax = "SCREEN(U(IN(Equity(active,public,primary))), IN(TR.ExchangeCountryCode,'BN','KH','ID','LA','MY','MM','PH','SG','TH'), CURN=USD)"
fields = ["TR.CommonName","TR.ExchangeCountry"]
df, err = ek.get_data(syntax, fields)
df
and here's the data returned
Hope this could help
1.4k 6 2 2
Hi @sc11214 ,
Have you had a read of Nick's article on the Search API?
Hi @raksina.samasiri this is very helpful thank you very much
