Retrieve specific historical company guidance
I am trying to get company historical revenue guidance for Quarters. I saw that some posts point to DIB to search, but all i am finding is the guidance for no of shares. This is what I am using to get revenue, but i am coming up on empty.
ek.get_data(['VMW'], ["TR.GuidanceLowValue", "TR.GuidanceLowValue.calcdate", \
"TR.GuidanceHighValue", "TR.GuidanceHighValue.calcdate"], \
{"SDate":"2020-01-01", "EDate":"2021-08-27", "Period":"FQ0", "Frq":"FQ"})
Thanks.
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonguidance
18k 21 12 20
Hi @andrej.krneta
You can replace "calcdate" with "origdate"
Thank you.
Hi, @chavalit.jintamalit
I am using what you suggested with the following formula:
fields = ["TR.GuidanceLowValue", "TR.GuidanceLowValue.origdate"]
rev_guide_df, err = ek.get_data([Ticker], fields, \
{'GuidMeasure':'REV', "SDate":start_date, "EDate":end_date, "Period":"FQ1", "Frq":"FQ"})
The output comes out as different guidance for the same origination date. Not sure how this can be. If the company changed their guide it must have been on different dates. What am I missing here?
How do I get a timestamp with the "TR.RevenueActSurprise" field alone? If I add .origdate to the same field, as you suggested, it does not seem to work.
This is what I have:
Ticker = 'INTC.O'
start_date = '2010-01-01'
end_date = '2021-08-27'
fields = ["TR.RevenueActSurprise", 'R.RevenueActSurprise.origdate']
But the date field returns empty values. I have two fields in the function call one for revenue surprise and the other for the date related to that reading. But, I am getting empty. appreciate the help.
1.7k 2 4 7
Hi @andrej.krneta ,
for this field, please use .calcdate instead,
below is an example of the code
Ticker = 'INTC.O'
fields = ["TR.RevenueActSurprise", 'TR.RevenueActSurprise.calcdate']
rev_guide_df, err = ek.get_data([Ticker], fields, {'GuidMeasure':'REV', "SDate":start_date, "EDate":end_date, "Period":"FQ1", "Frq":"FQ"})
rev_guide_df
Plus, below is how you can check which one can be used using DIB (check in Output dropdown list)
Thank you.
