SSLHandshakeException while calling TRKD API
javax.xml.ws.WebServiceException: javax.net.ssl.SSLHandshakeException: General SSLEngine problem
at com.sun.xml.ws.transport.http.client.HttpClientTransport.readResponseCodeAndMessage(HttpClientTransport.java:210)
at com.sun.xml.ws.transport.http.client.HttpTransportPipe.createResponsePacket(HttpTransportPipe.java:239)
at com.sun.xml.ws.transport.http.client.HttpTransportPipe.process(HttpTransportPipe.java:230)
at com.sun.xml.ws.transport.http.client.HttpTransportPipe.processRequest(HttpTransportPipe.java:143)
at com.sun.xml.ws.transport.DeferredTransportPipe.processRequest(DeferredTransportPipe.java:139)
at com.sun.xml.ws.api.pipe.Fiber.__doRun(Fiber.java:1136)
at com.sun.xml.ws.api.pipe.Fiber._doRun(Fiber.java:1050)
at com.sun.xml.ws.api.pipe.Fiber.doRun(Fiber.java:1019)
at com.sun.xml.ws.api.pipe.Fiber.runSync(Fiber.java:877)
at com.sun.xml.ws.client.Stub.process(Stub.java:464)
at com.sun.xml.ws.client.sei.SEIStub.doProcess(SEIStub.java:174)
at com.sun.xml.ws.client.sei.SyncMethodHandler.invoke(SyncMethodHandler.java:108)
at com.sun.xml.ws.client.sei.SyncMethodHandler.invoke(SyncMethodHandler.java:91)
at com.sun.xml.ws.client.sei.SEIStub.invoke(SEIStub.java:154)
at com.sun.proxy.$Proxy793.createServiceToken1(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at weblogic.wsee.jaxws.spi.ClientInstanceInvocationHandler.invoke(ClientInstanceInvocationHandler.java:84)
at com.sun.proxy.$Proxy792.createServiceToken1(Unknown Source)
at com.thomsonreuters.webservice.trkd.client.AuthorizationService.getAuth
rkd-apirkdssl
13.7k 26 8 12
If you are trying to connect through a proxy, have a look at this other query, it might help.
I already set my proxy as you explained. However issue is I am connecting through weblogic 12.2.1 server. There I can't connect although I use proxy. Outside weblogic server I am able to connect.
13.7k 26 8 12
@shodhan.shah
From what you write, the issue is not related to TRKD, but caused by the weblogic server. Please ask the weblogic support team for help on this.
