When using the 'eikon' module, the below code works, but using the 'refinitiv.dataplatform.eikon' module as per the tutorials, yields the below '_get_udf_url' attribute error. Running python 3.8. Any ideas on how to rectify?
Thanks in advance for any help!
import refinitiv.dataplatform.eikon as ek
# import eikon as ek
ek.set_app_key('xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx')
ek.get_timeseries('EUR=', interval='daily')
--------------------------------------------------------------------------- AttributeError Traceback (most recent call last) <ipython-input-44-d3cb9f2bda23> in <module> ----> 1 ek.get_timeseries('EUR=', interval='daily') ~\AppData\Local\dbconda-2021_05-py38-r36\lib\site-packages\refinitiv\dataplatform\legacy\time_series.py in get_timeseries(rics, fields, start_date, end_date, interval, count, calendar, corax, normalize, raw_output, debug) 199 raise ValueError(error_msg) 200 --> 201 response = refinitiv.dataplatform.legacy.json_requests.send_json_request( 202 TimeSeries_UDF_endpoint, payload, debug=debug 203 ) ~\AppData\Local\dbconda-2021_05-py38-r36\lib\site-packages\refinitiv\dataplatform\legacy\json_requests.py in send_json_request(entity, payload, ID, debug, raw_response) 86 udf_request = { "Entity": { "E": entity, "W": data}, "ID": ID} 87 logger.debug( ---> 88 "Request to {} :{}".format(_session._get_udf_url(), udf_request) 89 ) 90 response = _session.http_request( AttributeError: 'PlatformSession' object has no attribute '_get_udf_url'
