Create instrument list locally in TRTH REST API
Hi. For the past 26 years, each year I have an instrument list consisting of thousands of stocks' RIC's. I'm using R and I literally have a 'list' looking like: list=c('IBM.N', 'AAPL.O', 'MSFT.O', .....)
So my question is, how do I pass this list in my body? I'm aware that it can be done like:
But it would be impractical to pass thousands of RICs. I've also had a look at https://hosted.datascopeapi.reuters.com/RestApi.Help/Context/Operation?ctx=Extractions&ent=InstrumentList&opn=ImportFromBytes
But I don't know how to read this page and I'm still confused... So could I have some help? Thank you!
dss-rest-apidatascope-selectdsstick-history-rest-api
@ziucqea
To use this /Extractions/InstrumentListImportFromBytes endpoint, please refer to this discussion. You can use it to create a new instrument list saved on the DSS server.
You can also access the DSS GUI to import the instrument list.
To use the instrument list in the on-demand extraction, you need to know the ListId. To get the ListId, you can use the following endpoint. 'test1' is the name of my instrument list.
/Extractions/InstrumentListGetByName(ListName='test1')
The output is:
    "@odata.context": "https://selectapi.datascope.refinitiv.com/RestApi/v1/$metadata#InstrumentLists/$entity",
    "ListId": "0x07af0307431d1024",
    "Name": "test1",
    "Count": 1,
    "Created": "2021-08-25T08:31:18.603Z",
    "Modified": "2021-08-25T08:31:19.103Z"
The ListId of 'test1' is 0x07af0307431d1024. Then, we can use it in the on-demand extraction.
    "ExtractionRequest": {
        "IdentifierList": {
            "@odata.type": "#DataScope.Select.Api.Extractions.ExtractionRequests.InstrumentListIdentifierList",
            "InstrumentListId": "0x07af0307431d1024"
