I have followed below steps using curl:
1) get the authentication token which is working and generated token:
OdiOSCommand "-OUT_FILE=/home/oracle/Documents/OutFile/refinitiv_file.txt" "-CAPTURE_OUT_STREAM=ON_ERROR,10,50" "-CAPTURE_ERR_STREAM=ON_ERROR,10,50" curl -H "Content-Type: application/json" -H "Prefer: respond-async" -X POST -v -d "{\"Credentials\": {\"Username\": \"501\",\"Password\": \"xxxxxx\"}}" https://selectapi.datascope.refinitiv.com/RestApi/v1/Authentication/RequestToken
2) Use this authentication token in the below curl request:
OdiOSCommand "-OUT_FILE=/home/oracle/Documents/OutFile/refinitiv_file_extraction_response_json.txt" "-CAPTURE_OUT_STREAM=ON_ERROR,10,50" "-CAPTURE_ERR_STREAM=ON_ERROR,10,50" curl -X POST \ https://selectapi.datascope.refinitiv.com/RestApi/v1/Extractions/ExtractRaw \ -H 'Authorization: Token __7OGZ1r1Hp4HaTam98Gp9kmovQlNv8NeKEHe6boyIRJXnzNmdLSvnfJXcHysqu9JCgX6PH9nk30671SwRb1ol_dj9oG46BY3mG6JGMMNs17J_TZ7tP9RL2Y2q-6KaqL63EjjfWt9Bm-5usuI3alHDy5Q_AwVXoSW140O8x3AwNfhvOSUpxAllzXidWNXn27yfgHrMm28ZjKEycVqJOwfztmcr75tHj9ijvHogyaXzmiKpPv2sxc45aqEW2KnrKASN1zEhzw3ICrtDBm4Xhx9TzL2TB-XpBPDDWpaUi4jFdU' \ -H 'Content-Type: application/json' \ -d '{ "ExtractionRequest": { "@odata.type": "#DataScope.Select.Api.Extractions.ExtractionRequests.TickHistoryRawExtractionRequest", "ContentFieldNames": [ ], "IdentifierList": { "@odata.type": "#DataScope.Select.Api.Extractions.ExtractionRequests.InstrumentIdentifierList", "InstrumentIdentifiers": [ {"Identifier":"IBM.N","IdentifierType":"Ric"},{"Identifier":"CARR.PA","IdentifierType":"Ric"},{"Identifier":"BEGRs.TQE","IdentifierType":"Ric"},{"Identifier":"US1156371007.GTX","IdentifierType":"Ric"},{"Identifier":"JP3249600002.GTX","IdentifierType":"Ric"} ] }, "Condition": { "MessageTimeStampIn": "GmtUtc", "ReportDateRangeType": "Range", "QueryStartDate": "2021-08-20T00:00:00.000Z", "QueryEndDate": "2021-08-23T00:00:00.000Z", "Fids": "3,5,12,13,15,16,19,22,23,26,27,4196,5632,5633,2130", "DisplaySourceRIC": true } } }'
The output response for the above request is as below:
{"@odata.context":"https://hosted.datascopeapi.reuters.com/RestApi/v1/$metadata#RawExtractionResults/$entity","JobId":"0x07ae207dfead0ec8","Notes":["Extraction Services Version 15.0.42358 (01a7f7ea050d), Built May 20 2021 18:20:45\nUser ID: 7701\nExtraction ID: 2000000296050738\nSchedule: 0x07ae207dfead0ec8 (ID = 0x0000000000000000)\nInput List (1 items): (ID = 0x07ae207dfead0ec8) Created: 23.08.2021 15:58:07 Last Modified: 23.08.2021 15:58:07\nReport Template: _OnD_0x07ae207dfead0ec8 (ID = 0x07ae207dfecd0ec8) Created: 23.08.2021 15:56:55 Last Modified: 23.08.2021 15:56:55\nSchedule dispatched via message queue (0x07ae207dfead0ec8), Data source identifier (8A3F4C373BA140F98836FA4F5B502FC8)\nSchedule Time: 23.08.2021 15:56:56\nProcessing started at 23.08.2021 15:56:56\nProcessing completed successfully at 23.08.2021 15:58:07\nExtraction finished at 23.08.2021 13:58:07 UTC, with servers: tm02n02, TRTH (41.83 secs)\nInstrument <RIC,IBM.N> expanded to 1 RIC: IBM.N.\nTotal instruments after instrument expansion = 1\n\nManifest: #RIC,Domain,Start,End,Status,Count\nManifest: IBM.N,Market Price,,,Inactive,0\n"]}
3) This step i am not clear yet. In this step i tried to get the JobID and also previous token i have used from step 1 and use it another curl request to get the response values for the fids:
OdiOSCommand "-OUT_FILE=/home/oracle/Documents/OutFile/refinitiv_file_extraction_response_json_values.txt" "-CAPTURE_OUT_STREAM=ON_ERROR,10,50" "-CAPTURE_ERR_STREAM=ON_ERROR,10,50" curl -X GET \ https://selectapi.datascope.refinitiv.com/RestApi/v1/Extractions/RawExtractionResults('0x07ae2e231f1d0eeb')/$value \ -H 'Authorization: Token __7OGZ1r1Hp4HaTam98Gp9kmovQlNv8NeKEHe6boyIRJXnzNmdLSvnfJXcHysqu9JCgX6PH9nk30671SwRb1ol_dj9oG46BY3mG6JGMMNs17J_TZ7tP9RL2Y2q-6KaqL63EjjfWt9Bm-5usuI3alHDy5Q_AwVXoSW140O8x3AwNfhvOSUpxAllzXidWNXn27yfgHrMm28ZjKEycVqJOwfztmcr75tHj9ijvHogyaXzmiKpPv2sxc45aqEW2KnrKASN1zEhzw3ICrtDBm4Xhx9TzL2TB-XpBPDDWpaUi4jFdU' \ -H 'Content-Type: application/gzip' \ -H 'X-Direct-Download: True'
And this step is throwing an error as below:
ODI-1226: Step Copy of Refinitiv_RESTAPI_REQUEST fails after 1 attempt(s). ODI-1241: Oracle Data Integrator tool execution fails. Caused By: com.sunopsis.dwg.function.SnpsFunctionBaseException: ODI-30038: OS command returned 1. Error details are [sh: -c: line 1: syntax error near unexpected token `(' sh: -c: line 1: ` https://selectapi.datascope.refinitiv.com/RestApi/v1/Extractions/RawExtractionResults('0x07ae2e231f1d0eeb')/$value \' ]. at com.sunopsis.dwg.tools.OSCommand.actionExecute(OSCommand.java:535) at com.sunopsis.dwg.function.SnpsFunctionBaseRepositoryConnected.execute(SnpsFunctionBaseRepositoryConnected.java:235) at oracle.odi.runtime.agent.execution.SessionTask.execIntegratedFunction(SessionTask.java:949) at oracle.odi.runtime.agent.execution.SessionTask.executeOdiCommand(SessionTask.java:607) at oracle.odi.runtime.agent.execution.cmd.OdiCommandExecutor.execute(OdiCommandExecutor.java:32) at oracle.odi.runtime.agent.execution.cmd.OdiCommandExecutor.execute(OdiCommandExecutor.java:18) at oracle.odi.runtime.agent.execution.TaskExecutionHandler.handleTask(TaskExecutionHandler.java:52) at oracle.odi.runtime.agent.execution.SessionTask.processTask(SessionTask.java:216) at oracle.odi.runtime.agent.execution.SessionTask.doExecuteTask(SessionTask.java:128) at oracle.odi.runtime.agent.execution.AbstractSessionTask.execute(AbstractSessionTask.java:886) at oracle.odi.runtime.agent.execution.SessionExecutor$SerialTrain.runTasks(SessionExecutor.java:2225) at oracle.odi.runtime.agent.execution.SessionExecutor.executeSession(SessionExecutor.java:610) at oracle.odi.runtime.agent.processor.TaskExecutorAgentRequestProcessor$1.doAction(TaskExecutorAgentRequestProcessor.java:718) at oracle.odi.runtime.agent.processor.TaskExecutorAgentRequestProcessor$1.doAction(TaskExecutorAgentRequestProcessor.java:611) at oracle.odi.core.persistence.dwgobject.DwgObjectTemplate.execute(DwgObjectTemplate.java:203) at oracle.odi.runtime.agent.processor.TaskExecutorAgentRequestProcessor.doProcessStartAgentTask(TaskExecutorAgentRequestProcessor.java:800) at oracle.odi.runtime.agent.processor.impl.StartSessRequestProcessor.access$1400(StartSessRequestProcessor.java:74) at oracle.odi.runtime.agent.processor.impl.StartSessRequestProcessor$StartSessTask.doExecute(StartSessRequestProcessor.java:702) at oracle.odi.runtime.agent.processor.task.AgentTask.execute(AgentTask.java:180) at oracle.odi.runtime.agent.support.DefaultAgentTaskExecutor$2.run(DefaultAgentTaskExecutor.java:108) at java.lang.Thread.run(Thread.java:748)
