Error while installing packages for Refinitiv Data Platform
Hello, i have Anaconda3-2021.05-Windows-x86_64 installed on my system. On the Anaconda Prompt (Anaconda3) I type: pip install refinitiv-dataplatform
I get an error, as below. Not sure what is incorrect. This command i am told will install all packages related to Refinitiv Data Platform
pythonrdp-api
4.3k 2 4 5
Hi @d.patel ,
it seems httpx retrieving failed because due to a cache effect.
Could you clean your cache ('conda clean --all') ?
Then try to install httpx ('conda install httpx').
If it still failing, then uninstal httpx ('conda uninstall httpx'),
then reinstall refinitiv-dataplatform.
hello, thank you so much @pierre.faurel . I now face a syntax error in the Jupyter Notebook. Any idea what is wrong here?
Hi @d.patel
As the APP_KEY is meant to hold a String value so, it needs to be in quotes e.g.
APP_KEY="mylovelyappkey124abcd1123223"
thank you @umer.nalla this was helpful! :) appreciate the support so far. It worked! :)
