404 error when pulling I/B/E/S data
Hi, I am trying to get I/B/E/S data through the refinitiv API with python but I keep on getting a 404 error. I use python 3.7 and this is the endpoint I use:
https://api.refinitiv.com/data/estimates/beta1/viewsummary/annual
My authorizations are fine, I run other code examples and I get the data correctly. Also I am using IBM.N as universe and basic as package. This is the error I get:
Unable to get data. Code 404, Message: 404 page not found
Any idea of what I am doing wrong?
pythonrdp-apirefinitiv-data-platformerror-404estimates
Hi @sc11214
Thanks for sharing - there is a typo in your code
As per my above post, it should be
endpoint_URL = "/view-summary/annual"
note the '-' between view and summary
Great that works. Thanks a lot
Hi, yes I did try but I get the same error
Hi @sc11214
Can you please share the code snippet you are using? You can attach it as a .txt file (removing any credentials or other confidential information).
Hi, sure thanks. I basically use the code sample provided by refinitiv and I make a few changes to get the estimates code_snippet.txt
the rdpToken library is the one provided by refinitive and it works as I am able to run the other examples
