RSSL_HTTP Channel type leads to HttpChannelConfig cannot be cast to SocketChannelConfig exception
I'm using EMA 3.0.0.L1 in order to connect to Electron.
I tried to switch client library to RSSL_HTTP channel type (from standard RSSL_SOCKET) and got
an exception from EMA library:
Exception in thread "main" java.lang.ClassCastException: com.thomsonreuters.ema.access.HttpChannelConfig cannot be cast to com.thomsonreuters.ema.access.SocketChannelConfig
    at com.thomsonreuters.ema.access.ChannelCallbackClient.initialize(ChannelCallbackClient.java:596)
    at com.thomsonreuters.ema.access.OmmConsumerImpl.initialize(OmmConsumerImpl.java:194)
    at com.thomsonreuters.ema.access.OmmConsumerImpl.<init>(OmmConsumerImpl.java:91)
    at com.thomsonreuters.ema.access.EmaFactory.createOmmConsumer(EmaFactory.java:158)
    at com.trgr.discorch.electron.ElectronClient.<init>(ElectronClient.java:249)
    at com.trgr.discorch.electron.ElectronClient.getInstance(ElectronClient.java:237)
    at com.trgr.discorch.electron.Application.main(Application.java:25)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    at java.lang.reflect.Method.invoke(Method.java:498)
    at com.intellij.rt.execution.application.AppMain.main(AppMain.java:147)
According to the code
case 2:
    connectOptions.tunnelingInfo().tunnelingType("http");
    connectOptions.unifiedNetworkInfo().interfaceName(((SocketChannelConfig)activeConfig.channelConfig).interfaceName);
we are really trying to cast HttpChannelConfig to SocketChannelConfig.
Example of EmaConfig.xml used in my client:
<ChannelGroup>
    <ChannelList>
        <Channel>
            <Name value="Channel_1"/>
            <!--<ChannelType value="ChannelType::RSSL_SOCKET"/>-->
            <ChannelType value="ChannelType::RSSL_HTTP"/>
            <!-- CompressionType is optional: defaulted to None                                            -->
            <!-- possible values: None, ZLib, LZ4                                                        -->
            <CompressionType value="CompressionType::None"/>
            <GuaranteedOutputBuffers value="5000"/>
            <!-- ConnectionPingTimeout is optional: defaulted to 30000                                    -->
            <ConnectionPingTimeout value="30000"/>
            <!-- TcpNodelay is optional: defaulted to 1                                                 -->
            <!-- possible values: 1 (tcp_nodelay option set), 0 (tcp_nodelay not set)                    -->
            <TcpNodelay value="1"/>
            <Host value="localhost"/>
            <Port value="14002"/>
            <XmlTraceToStdout value="1"/>
        </Channel>
    </ChannelGroup>
<ChannelList>
elektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-apiexception
I have the same issue with emaj3.0.2.all.rrg from Electron Java SDK 1.0.5
According to the information in the EMA Java configuration guide, EMA Java doesn't support RSSL_HTTP channel type. Currently, it only supports RSSL_SOCKET.
I got the same result. However, after commenting that line in EMA code, it works.
case com.thomsonreuters.upa.transport.ConnectionTypes.HTTP:
	//connectOptions.unifiedNetworkInfo().interfaceName(((SocketChannelConfig)activeConfig.channelConfig).interfaceName);
        break;
The interface will be set again after the switch command.
        connectOptions.unifiedNetworkInfo().interfaceName(activeConfig.channelConfig.interfaceName);
	connectOptions.unifiedNetworkInfo().unicastServiceName("");
However, to make it work, you need to set TcpNodelay to 0.
	<TcpNodelay value="0"/>
In conclusion, this could be a bug in EMA Java so I will raise the issue to development team.
