Eikon API R NOT WORKING
get_timeseries(rics = ricsH,
               fields = list("TIMESTAMP", "CLOSE"),
               start_date = paste(SoyaFC$Date[nrow(SoyaFC)] + 1, "T00:00:00", sep = ""),
               end_date = paste((today() - 1), "T00:00:00", sep = ""),
               interval = "daily",
               normalize = TRUE,
               raw_output = TRUE)
Two weeks back I was able to run this code with no issue. Now it is giving me weird output that I can't make sense of and I can't convert it from JSON to text.
I'm getting the following error:
Error: lexical error: invalid char in json text.
                                       <!DOCTYPE HTML PUBLIC "-//W3C//
                     (right here) ------^
What might the issue be?
eikonworkspaceworkspace-data-apirefinitiv-dataplatform-eikonerrortime-serieseikon-data-api-r
@devilliersk
One scenario that can trigger this issue is the current Eikon user is used somewhere else.
For example, while using Eikon Data API on the desktop, I use the same Eikon user to log in to the Refinitiv Workspace Web.
After re-running the code, I got the following error.
Traceback:
1. eikonapir::get_timeseries(rics, fields = query_fields, start_date = "2020-01-01T00:00:00",
 .     end_date = "2020-11-01T00:00:00", interval = "daily")
2. jsonlite::fromJSON(json_data)
3. parse_and_simplify(txt = txt, simplifyVector = simplifyVector,
 .     simplifyDataFrame = simplifyDataFrame, simplifyMatrix = simplifyMatrix,
 .     flatten = flatten, ...)
4. parseJSON(txt, bigint_as_char)
5. parse_string(txt, bigint_as_char)
If you check the raw output, it returns the sign-in HTML page.
I need to re-login to Eikon to make the application work again.
