Hi!
I would like to automatize an Excel, to open up and refreshing some quotes, saving it, and closing the file. Now this my VBA manages. This works perfectly when I’m signed in.
But sometimes I am not signed in (for any reason), and then the VBA stops mid-air. I tried already googling and found one guideline(see below), but I cannot manage to get it to work.
Can someone help me? What am I doing wrong?
I copied the line and enabled Automatic Login:
CreateReutersObject code
Public Function CreateSynchronizationMgr() As PLSynchronizationMgrLib.SynchronizationMgr
Set CreateSynchronizationMgr = CreateReutersObject("PLSynchronizationMgr.SynchroMgr")
End Function---------------------------------------------------------
I assume I need this VBA, but I cannot run it in my Workbook (even though I have taken the same “PLVbaApis” module to my Project.
#If VBA7 Then
Private Declare PtrSafe Function CreateReutersObject Lib "PLVbaApis.dll" (ByVal progID As String) As Object
#Else
Private Declare Function CreateReutersObject Lib "PLVbaApis.dll" (ByVal progID As String) As Object
#End If
' Synchronization Manager - added manually, not in original PlVbaApis.bas.
End Function
Private Sub cmdLogIn_Click()
Dim strConnState As String
If myPLSM Is Nothing Then Set myPLSM = CreateSynchronizationMgr()
With myPLSM
Select Case .ConnectionState
'PLConnectionStateType
'PL_CONNECTION_STATE_NONE 0
'PL_CONNECTION_STATE_MINIMAL 1
'PL_CONNECTION_STATE_WAITING_FOR_LOGIN 2
'PL_CONNECTION_STATE_ONLINE 3
'PL_CONNECTION_STATE_OFFLINE 4
'PL_CONNECTION_STATE_LOCAL_MODE 5
Case 0
strConnState = "0 - PL_CONNECTION_STATE_NONE"
Case 1
strConnState = "1 - PL_CONNECTION_STATE_MINIMAL"
Case 2
strConnState = "2 - PL_CONNECTION_STATE_WAITING_FOR_LOGIN"
Case 3
strConnState = "3 - PL_CONNECTION_STATE_ONLINE"
Case 4
strConnState = "4 - PL_CONNECTION_STATE_OFFLINE"
Case 5
strConnState = "5 - PL_CONNECTION_STATE_LOCAL_MODE"
End Select
MsgBox "Connection State: " & strConnState
If .ConnectionState = 2 Or .ConnectionState = 4 Then
'' Two ways of logging in programmatically.
'' If the user log in details are already set for automatic log in, this will log in EfE.
'' Or provide the log in dialogue box otherwise.
'.Login
Application.Run "PLLoginEventHandler"
End If
End With
End Sub
Reuters Eikon MS Office version 4.0.34563
MS Offic Version 2010 Microsofr Office System, MSO (14.0.7166.5000)
Windows 7 Enterprise 64-Bit
