TR.COUNTRYHQ no longer works?
I am trying to pull the field TR.COUNTRYHQ for a particular RIC but it is not working. Any suggestions on what this field might have been changed to?
rdp-apirefinitiv-data-platformexcel
Hello @oliver.rogers19 ,
Can you please share the complete call, so that we can try the same on our side?
23k 22 9 14
Hi @oliver.rogers19 ,
Seeing same as @nick.zincone.1.
If you wish to confirm in reference to requesting via EDAPI, which fields are available/populated for instruments, you may find Data Item Browser tool on Eikon/Refinitiv Workspace indispensable for this purpose. Foe example, looking up Country Headquarters for VALE3.SA I see:
But no TR.COUNTRYHQ . Resulting in the call not working.
Great thank you for mentioning Data Item Browser, this looks very helpful
t_data(' VALE3.SA', ['TR.COUNTRYHQ'])
9.7k 49 38 60
Hi @oliver.rogers19
I don't know what API you are using: t_data()? Are you accessing your data from Eikon or Refinitiv Workspace? Or directly to RDP? If RDP, what endpoint are you using?
Using the Eikon Data API, this call works:
df,err = ek.get_data("VALE3.SA", ["TR.HeadquartersCountry"])
df
Thanks for the answer and apologies I pasted my comment incorrectly - it should have read:
Country = rdp.get_data(' VALE3.SA', ['TR.COUNTRYHQ'])
