FX Prices return zero
Could you provide a sample on how to pull an FX quote using Excel?
After reading the DDE usage guide, i tried =RediLink|FXQ!'AUD/USD;CROSS,SB' which will return the pair in the first cell (as desired) and then zero as the spot bid.
It does the same when i replace SB with SA for spot ask.
excelredi-apiforexdde
Hi @ds01,
The example of usage in DDE Usage Guide that you are looking at should be good.
I am going to request to confirm, if you/your user are permissioned for FX via DDE, as this could be the reason why. Will keep you informed of the findings.
Thanks Zoya. Please let me know if I can provide anything to help.
Hi @ds01 ,
Please see below for a sample.
Before trying this, I recommend checking with your support representative to ensure you're entitled for FX quotes in the REDI API.
Thanks,
Brian
