Failing RICs
Hi there
Following RICs give no match through the mapping API (randomly it might work for times to times):
SATG_p.DE
IIP_u.TO
SESFd.PA
BIP_u.TO
HR_u.TO
WIR_u.TO
BPY_u.TO
CUF_u.TO
ROG.S
NWH_u.TO
GRT_u.TO
CRR_u.TO
BEP_u.TO
BEI_u.TO
326030.KS
FPEG_p.DE
FCR_u.TO
CSH_u.TO
CRT_u.TO
AP_u.TO
TIGOsdb.ST
PSHG_p.DE
AX_u.TO
Thanks for checking.
best simon
intelligent-tagging-apipermid-apiopen-permid-api
@simon.keel
I checked and found that the problem has been resolved.
SATG_p.DE maps to https://permid.org/1-55837360918..
@simon.keel
Yes, you are correct. It is unstable. I am using Quote match.
LocalID,Standard Identifier
1,RIC:SATG_p.DE
2,RIC:IIP_u.TO
3,RIC:SESFd.PA
4,RIC:BIP_u.TO
5,RIC:HR_u.TO
6,RIC:WIR_u.TO
7,RIC:BPY_u.TO
8,RIC:CUF_u.TO
9,RIC:ROG.S
10,RIC:NWH_u.TO
11,RIC:GRT_u.TO
12,RIC:CRR_u.TO
13,RIC:BEP_u.TO
14,RIC:BEI_u.TO
15,RIC:326030.KS
16,RIC:FPEG_p.DE
17,RIC:FCR_u.TO
18,RIC:CSH_u.TO
19,RIC:CRT_u.TO
20,RIC:AP_u.TO
21,RIC:TIGOsdb.ST
22,RIC:PSHG_p.DE
Sometimes, it returns No Match.
I will contact the PermID support team to verify the problem.
@jirapongse.phuriphanvichai do you have updates on this? the issues still persists...
@simon.keel
I have tested it several times and it always returns "No match".
Are you still getting the Matched results for those items?
@jirapongse.phuriphanvichai : that's exactely the issue, the RIC SATG_p.DE should map to
or am I not getting something?
@simon.keel
Got it. I will contact them for the answer.
@jirapongse.phuriphanvichai any upddates on this issue?
@simon.keel
Sorry, there is no update on this issue.
I have contacted the support team for updates.
