Websocket API didn't receive response after Service Discovery Call
Hello!
We succesfully received token via https://api.refinitiv.com:443/auth/oauth2/v1/token
and then we are trying to call https://api.refinitiv.com/streaming/pricing/v1/?transport=websocket.
But this https://api.refinitiv.com/streaming/pricing/v1/?transport=websocket does not return anything.
One day ago, the request https://api.refinitiv.com/streaming/pricing/v1/?transport=websocket correctly returned a list of endpoints.
If i try to call https://api.refinitiv.com/streaming/pricing/v1/?transport=websocket via browser it return
code"401"message"Authorization header is missing"status"Unauthorized"
so we has an network access.
What it can be?
rdp-apirefinitiv-data-platformwebsockets
Hi @elektron
Are you using C#?
If so, there is an issue due to the increase in the number of services added over the weekend, the response has started being chunked.
As a result of this, if you are using the C# example or another scenario where you are checking the service discovery response content length - this would now return -1 and something like the following would now fail:
if (webResponse.ContentLength > 0)
so the above should be replaced with something like:
if (webResponse.GetResponseHeader("Transfer-Encoding").Equals("chunked") || webResponse.ContentLength > 0)
Hope this helps.
If you were using our C# service discovery example on Github, these will be updated shortly.
11.5k 16 7 10
Hello @elektron
Could you please try the Service Discovery request with the following curl command? Please replace the <access_token> with your Access Token from the RDP Auth Token service (Note: please notice a space between text 'Bearer' and the access token).
curl --location --request GET 'https://api.refinitiv.com/streaming/pricing/v1/' \
--header 'Accept: application/json' \
--header 'Authorization: Bearer <access token>'
If you still encounter errors from the curl command, I suggest you contact the RDP support team via https://my.refinitiv.com/ website to help you verify the issue.
Please select the "Pricing - Refinitiv Data Platform" product on the my.refinitiv.com website, and give them the following information:
Hope this helps.
Hi @elektron
If you are using the github example, please note that as well as the above fix, there was another minor fix applied to the code - so recommend you download the latest version.
websocket-api/MarketPriceRdpGwServiceDiscoveryExample.cs at master · Refinitiv/websocket-api (github.com)
Thank you for infromation.
Yes, we are using C # and will try to fix it with the provided examples.
Hello!
Which product do I need to subscribe to at https://my.refinitiv.com/ in order to receive similar notifications?
Hi @elektron - sorry don't understand your question - what kind of notifications do you require?
Thanks.
Hi @umer.nalla, i want to receive notifications about changes in API web socket.
i've alredy subscribed to "Refinitiv Real-Time - Optimized" alerts. What alerts do I need to subscribe to? please tell me is that enough?
Hi @elektron
You could watch the GitHub repo for Websocket API to be made aware of any changes.
We hope to add a 'Watch API' functionality on the Developer Portal - but I don't have a timescale for this.
