Downloading the XSD file for DSS Extraction file
Is it possible to download the XSD schema of the output from a Report Template from DSS?
The report template itself can be downloaded in XML, where the format for each element is noted, but this cannot be used to infer an XML schema - for that the XSD file is required.
dss-rest-apidatascope-selectdssdss-gui
23k 22 9 14
Hello @Brinch ,
Do not believe XSD is made available , however, in my best understanding, XSD defines XML and the interaction with DSS REST service is JSON.
However, DSS REST API Reference is made available both as DSS REST API Reference Tree, primarily for visual/human lookup and also as DSS REST API Reference XML, suitable both for visual lookup and for programmatic parsing. Metadata is defined for separate endpoints, to provide the full schema for the requests and results from DSS REST API.
Hope this information can be of use for your requirement
