How to get historical times series for Central Bank of Russia key rate with Eikon API in Python?
Good afternoon!
I need to download historical values of Central Bank of Russia key rate from 2014 till today with Eikon Data API in Python. How can I do this?
I have found three rics for this key rate:
  1. RUKEYRATE=CBRF
  2. RUCBIR=ECI
  3. RUCBIR=ECIX
I decided to use the first, because I can not find any fields for the other two in Data Item Browser.
My code in Python:
today_str = datetime.strftime(datetime.today(), format="%Y-%m-%d")
keyRate, err = ek.get_data(instruments=['RUKEYRATE=CBRF'],
                           fields={'CF_CLOSE':{'SDate':'2014-01-01',
                                               'EDate':today_str}})
keyRate
When I use 'CF_CLOSE' in fields parameter, NaN is returned; 'CF_LAST' returns only last value of the key rate, and I need historical time series.
Any help is appreciated.
@Alex Putkov. would be great if you could give some advice.
@lozovoy.hse
The CF_LAST and CF_CLOSE fields are real-time fields that don't provide time-series data with the get_data method.
You need to use fields that support time-series such as TR.ClosePrice. From my checking, the TR.ClosePrice field is not available for those RICs. You can re-verify it by using the Data Item Browser. Otherwise, you can directly contact the content support team via MyRefinitiv to verify it.
However, I can retrieve time-series data of those RICs via the get_timeseries method.
df = ek.get_timeseries(['RUKEYRATE=CBRF'],
                       start_date = "2014-01-01",
                       end_date=today_str,
                       interval="daily")
RUCBIR=ECI and RUCBIR=ECIX don't support the daily interval so I change the interval to monthly.
df = ek.get_timeseries(['RUCBIR=ECI','RUCBIR=ECIX'],
                       end_date=today_str,
                       interval="monthly")
The get_timeseries method has data limitations, as mentioned in the Eikon Data API Usage and Limits Guideline.
1.4k 6 2 2
Hi @lozovoy.hse ,
I would advise searching for fields on the DIB that do not have blank values by ticking the 'Blank Values' box in the settings on the top right:
You can also filter through time series fields only. Doing this, I found that this instrument does not lend itself well to the Python EDAPI, it is more meant for real time analysis; I'm guessing that this is not the kind of analysis you have in mind.
May I advise using Datastream? Or is that not an option?
On Datastream, you can have such historical data-sets
@jonathan.legrand Thank you for immediate response, but I have no access to Datastream.
@jirapongse.phuriphanvichai Thank you very much! The code works fine, I can download what I needed.
