A client is using the latest EMA Java 2.0.1 connecting to RTO with a streaming request. They are experiencing the following behavior/error message:
We monitored another couple times of the behavior.
one time it stopped refresh rates after 18 minutes of working.
Another time it stopped refresh rates after 10 minutes.
Both reported the following error messages.
Item Name: ZMW=
Service Name: ELEKTRON_DD Item State: Open / Suspect / None / 'channel down.' Jul 07, 2021 11:33:59 AM com.refinitiv.ema.access.ChannelCallbackClient reactorChannelEventCallback INFO: loggerMsg ClientName: ChannelCallbackClient Severity: Info Text: Received ChannelUp event on channel Channel_4 Instance Name Consumer_4_1 Component Version ads3.4.2.L1.linux.tis.rrg 64-bit loggerMsgEnd Jul 07, 2021 11:33:59 AM com.refinitiv.ema.access.LoginCallbackClient rdmLoginMsgCallback SEVERE: loggerMsg ClientName: LoginCallbackClient Severity: Error Text: RDMLogin stream was closed with status message username usernameType 5 State: Closed/Suspect/Application is denied access to the system - text: "TREP authentication failed (1026, Request for token validation failed:Authentication server did not contain "active" in response)." loggerMsgEnd
