Setting XmlTraceToStdout programatically
We are not using an EmaConfig.xml. Is there a way to enable XmlTraceToStdout programatically in JAVA?
elektronrefinitiv-realtimeelektron-sdkrrtema-apijava
11.5k 16 7 10
Hello @andre.malenfant
You can find an example of how to configure the EMA configurations programmatically in the EMA Java ex421_MP_ProgrammaticCfg example. The example shows how to set the XmlTraceToStdout parameter too.
Map innerMap = EmaFactory.createMap();
Map configMap = EmaFactory.createMap();
ElementList elementList = EmaFactory.createElementList();
ElementList innerElementList = EmaFactory.createElementList();
elementList.add(EmaFactory.createElementEntry().ascii("DefaultConsumer", "Consumer_1" ));
innerElementList.add(EmaFactory.createElementEntry().intValue( "XmlTraceToStdout", 1 ));
