Extracting All Canadian Preferred Shares Using Refinitiv Data Platform
I'm looking for the syntax to pull all Canadian Preferred Shares using the Search function in RDP. I'm interested in the following fields:
- volume
- shares outstanding
- CFI
- LEI/CUSIP/ISIN
- RIC
This is the code I currently have at the moment that does not pull anything:
filterStr = "RCSCountryLeaf eq 'Canada' and RCSAssetCategoryLeaf xeq 'Preferred Share'"srchfields = "Country, RIC, FullName, CommonName,CompanyName, SeniorityType, NativeIdentifier, DerivedCategory, OriginalIssueCurrency, ParentIndustrySector, CouponCurrency, CouponTypeDescription, CFI"GroupSize = 10000 #max at 10000 data = rdp.search(view=rdp.SearchViews.EquityInstruments, filter=filterStr, top=GroupSize, select=srchfields)
Any help is greatly appreciated, I can't find too much official documentation on this topic
Regards
rdp-apirefinitiv-data-platform
@cchen01
The RCSCountryLeaf field is not available in the rdp.SearchViews.EquityInstruments view. You need to use RCSIssuerCountryLeaf instead.
filterStr = "RCSIssuerCountryLeaf eq 'Canada' and RCSAssetCategoryLeaf xeq 'Preferred Share'"
srchfields = "RCSIssuerCountryLeaf, RCSAssetCategoryLeaf, Country, RIC, FullName, CommonName,CompanyName, SeniorityType, NativeIdentifier, DerivedCategory, OriginalIssueCurrency, ParentIndustrySector, CouponCurrency, CouponTypeDescription, CFI"
GroupSize = 100 #max at 10000
data
The output is:
You can view all available fields in the rdp.SearchViews.EquityInstruments view by using the following code.
rdp.get_search_metadata(view=rdp.SearchViews.EquityInstruments)
Hi @jirapongse.phuriphanvichai
After implementing this code, I pull a dataframe the size of [372 x 6]. Using the search app in Eikon, it pulls 4,566 preferred shares.
Is there a reason why RDP SearchView only pulls 372 entries?
@cchen01
From my checking, the EquityInstruments view doesn't have this RIC: AGQPF.PK.
Therefore, you can try the EquityQuotes view instead.
data = rdp.search(view=rdp.SearchViews.EquityQuotes, filter=filterStr, top=GroupSize, select=srchfields)
data
It returns 7015 rows.
