Getting data frame directly from using news API
In Eikon, news code [HNXB] contains headlines with links to download the file. Is there a way for us to download the data frame directly via Codebook? I'm only able to get the headlines but couldn't find a code that would extract the data directly.
ek.get_news_headlines(query = 'HNXB', count=10)
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikoncodebook
18k 21 12 20
Hi @chrisma.salut
Step 1: get headline
Step 2: get story id
I can only add 2 pictures in an answer, so please see further comment on this answer for more detail.
Step 3: get Side by Side API token with Eikon Desktop
Step 4: prepare Side by Side API command
Step 5: open the URL using the prepared command
url = 'http://127.0.0.1:9000/sxs/v1'
headers = {
    'Content-Type': 'application/json',
response = requests.request('POST', url, data=commandString, headers=headers)
print(response.text)
6.7k 8 6 7
@chrisma.salut So im thinking that you are looking to retrieve the news stories - so get_news headlines returns a dataframe of max 100 items per API call corresponding to a query you give it - in your case 'HNXB'.
df = ek.get_news_headlines(query = 'HNXB', count=10)
df
So this returns a dataframe of 10 headline items and you need to pass the storyId to a second API called get_news_story - which will return you the html formatted story text. The folllowing routine stores the formatted html news story in a new column called storytext.
df['storytext'] = ''
for i, uri in enumerate(df['storyId']):
    df['storytext'][i] = ek.get_news_story(uri)
df
You can display the story using:
from IPython.display import HTML
HTML(df['storytext'][0])
I have noticed in your query the news story text is actually a download link - if you changed the query to say VOD.L and repeated the exercise - it would display a news item. It is working correctly. I hope this can help.
Hello Chavalit,
Thank you for your assistance on this query. Client can't get past step 3 as they are getting an error. Any idea what's causing this?image001.jpg
Hi all, I dont verified your answers because it doenst match the requirement : downloading the file not the news. I found out my own way without applying any side to side api :
###1. get the table news
###2. get the story id
###2. get the file (downloaded in download folder)
df1Id=df1[df1['date']== a]['storyId'][0]
df1_url=ek.get_news_story(df1Id)
link1 = re.search('href="(.*)" data-type', df1_url)
webbrowser.open(link1.group(1))
@khangdiep Sorry we did not hit the mark this time. Thanks for taking the trouble to post your solution here - i'm sure others in the community will benefit from this addition. I have verified that this does indeed open the link in the webbrowser - however it does not download the file. From here you could try to scrape the rendered HTML I suppose. Once again thanks so much for contributing your solution.
the file is downloaded in "download" folder as the default location from website download. the download window is popped up and ask to choose the save folder location - but u can skip this step as keep running the code to download the other news file til the code end.
