Cannot initiate Eikon python - Error on checking port 9000
Hello, since today I started getting this error below after initiating Eikon in Python using the code below. I've used the same code for years by now, today stopped working.
Any ideas?
ek.set_app_key(<my_key>)
=============================== ERROR MSG =============================
Error on checking port 9000 : HTTPConnectionPool(host='localhost', port=9000): Read timed out.
Error on checking port 36036 : HTTPConnectionPool(host='localhost', port=36036): Max retries exceeded with url: /api/v1/data (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x000002295CA5F388>: Failed to establish a new connection: [WinError 10061] No connection could be made because the target machine actively refused it'))
Error on handshake port None : Failed to parse: localhost:None
Port number was not identified.
Check if Eikon Desktop or Eikon API Proxy is running.
@MJF
It looks like Eikon is not running properly. Please refer to Eikon Data API(Python) Troubleshooting to verify the problem.
