Cannot map SK Biopharmaceuticals Ord Shs
Hi
When I try to map
RIC:326030.KS
to
https://permid.org/1-21756071728
This fails.
Could you please check why this is the case?
Thanks and best
Simon
intelligent-tagging-apipermid-apiopen-permid-api
@simon.keel
The development team has fixed this issue. I have tested it and found that the API can return the data properly.
thank you!
@simon.keel
It could be the same problem reported in this question (RIC not found for SKBP ORD: 326030.KS).
I will contact the PermID support team for an update.
@jirapongse.phuriphanvichai , do you have update on the matter? still seeing the same issue....
@simon.keel
They are still working on this issue with the development team.
