EMA Example: opening item stream with a list of field IDs gets error with code -4048
Hi the following code (taken from the EMA Example series consumer/series300/ex360_MP_View:
ReqMsg reqMsg = EmaFactory.createReqMsg()
.name("/IBN.N")
.serviceName("ELEKTRON_DD")
.domainType(6);
ElementList view = EmaFactory.createElementList();
OmmArray array = EmaFactory.createOmmArray();
array.fixedWidth(5);//Subscribe to 5 fields
array.add(EmaFactory.createOmmArrayEntry().intValue(19));
array.add(EmaFactory.createOmmArrayEntry().intValue(22));
array.add(EmaFactory.createOmmArrayEntry().intValue(134));
array.add(EmaFactory.createOmmArrayEntry().intValue(15));
array.add(EmaFactory.createOmmArrayEntry().intValue(25));
view.add(EmaFactory.createElementEntry().uintValue(EmaRdm.ENAME_VIEW_TYPE, 1));
//!!!!!THIS LIVE THROWS AN EXCEPTION
view.add(EmaFactory.createElementEntry().array(EmaRdm.ENAME_VIEW_DATA, array));
And teh exception is:
Exception Type='OmmInvalidUsageException', Text='Unsupported fixedWidth encoding in encoding entry of Int type. Fixed width='5'. ', Error Code='-4048'
If I try with 4 fields it work correctly!
Thank you
elektronrefinitiv-realtimeelektron-sdkrrtema-apiOMM
Hi @DimAngelNX
Please see this article Enterprise Messaging API (Java) - Batch and View features | Refinitiv Developers
The FixedWidth method is not for the number of fields - it sets the fixed width of each array entry size - you can leave it the value of 2 (as used in the examples)
You may also find the following previous post useful:
Exception Type='OmmInvalidUsageException' when using fixedWidth in view Array - Forum | Refinitiv Developer Community
Ok thanks,
array.fixedWidth(2) it works fine!
