Method to Include Preferred Shares in Screener App?
I want to include the RIC's of Preference shares when pulling all Canadian-traded equities in Screener. Currently, filtering for Canadian-traded equities only displays ordinary shares. Is there a way to include preferred shares too?
By doing this I want to apply different columns such as volume to the preferred shares.
Eventually, I want to export as formula and use the Eikon Data API to pull the data into Python.
Thanks,
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonscreener
Screener provides search for companies, not for issues. It returns the RIC for the primary issue of the company, which is typically a common stock. I don't believe there's a way to get what you're looking for from Screener.
For your purpose I would recommend using the Search service on RDP. See the article titled "Building Search into your Application Workflow" for details.
Is there a way to achieve this without using Screener or RDP? I am running into issues using RDP.
11.5k 16 7 10
Hello @cchen01
There is the Find Your Right Companies with SCREENER article about how to use SCREENER with the Eikon Data API, hope this helps.
