Downloading ownership data for several firms on Eikon
Good morning Sirs, I would like to receive your help in order to download ownership data for a series of european listed firms. I am using screener but the data on the number of shareholders are not available for the majority of firms. However, as I check a single firm and I view its ownership report, the number of investors it's available.
How can I download ownership data for all firms without checking single ones? Tha dataset it's composed by 3000 firms so it will be very time consuming to check each individual company.
Thanks,
dr. Giovanni Coppola
PhD student in Management
eikoneikon-com-apidata
@dr.giovannicoppola
Could you specify which field name you use to retrieve the number of shareholders, and give an example of a stock where you see the data in Eikon application, but where the field you use to retrieve this data in Screener does not return the same figure you see in Eikon application?
