I tried using the API for extractRaw and it worked to give Job ID but I did not get any data calling the JobID.
Using the url in Chrome; gives the result.
Below what we get in response.
JobID request call
time:2021.06.08D21:26:22.927414000 tz:gmt logLevel:INFO messageType:Sending command: curl -s -i -X GET -H "Prefer: respond-async" -H "Content-Type: application/json" -H "X-Direct-Download: true" -H "Authorization: Token _hyZh8eP0XmiAP9427bWJFQ_98eyHW5ASl4Gk7vDKQk6kpA5J-97x8AC1W-XR7kx-dGgfnsPncO4Ql4qROp6W03Bhd5VI5NuG_yjsscDkXT2SC8lAddyNPp9R-wP3G2F7HR1aIjJ3WewDu5cN7a3eq7D-XkOIPAytwHnlQ7Zsge4YlMgtRmGsP17d6b2-ZzqdUaQRz1YFgYWK3ZSdQ_6NVm1CVe-e4uPb-rXu-s476POL7qHOHcirXXe82yDPYkF0s3MFS1Sb36SFFCeqJpEVvw9B2fvTUVb2xqDsgPm0WoA"https://selectapi.datascope.refinitiv.com/RestApi/v1/Extractions/RawExtractionResults('0x0796121379ccb766')/$value
response
(`responseHeader`responseLoad)!(("HTTP/1.1 200 Connection established";"";"HTTP/1.1 200 OK";"Cache-Control: no-cache";"Pragma: no-cache";"Content-Type: application/json; charset=utf-8";"Expires: -1";"Server: Microsoft-IIS/10.0";"X-Request-Execution-Correlation-Id: CiD/9015517/AAAAAA.0796145edd7cb774/RA";"X-App-Id: Custom.RestApi";"X-App-Version: 14.5.72.64";"Date: Tue, 08 Jun 2021 21:26:25 GMT";"Content-Length: 141";"");{"@odata.context":"https://selectapi.datascope.refinitiv.com/RestApi/v1/$metadata#RawExtractionResults/$entity","JobId":"0x0796121379ccb766"})
