Is there a re-branded version of RFA 7.0?
We've got a notification about the rebranding and new versions of API.
Currently, we use RFA 7. Is there a new version of it with Refinitiv brand, namespaces etc?
In the list of available products I can see Refinitiv Realtime SDK C++. But it looks like it's an Electron replacement.
Update: I've found rfa7.7.0.L1.win-shared.rrg. Based on REBRAND_RFACPP.txt file content, there are no changes in the interface or visible interfaces. And the changes are only in the documentation.
I can see the namespaces are still like rfa::common. I overrode existing RFA dlls (7.6.2) with new and I could compile the project without an issue. (I didn't try to run it). Is there anything required to do to use new RFA 7.7?
treprfarfa-api
Hi @igorg
Please see the following summary from a previous customer session on Rebranding:
As you will note from the Application changes required column, the answer is NO for RFA C++
Hello @igorg,
Please visit the API overview page. It contains the release notes as well as a downloads tab, from where you can download the latest version of rebranded SDK.
Why SDK?
I checked that page. Please read my "Update" part of the question.
11.5k 16 7 10
Hello @igorg
There is the API Rebranding documentation available on this https://my.refinitiv.com/content/mytr/en/pcnpage/12072.html?_ga=2.168693349.550228629.1623035797-601733482.1598596397 page.
Hope this helps.
Hello @wasin.waeosri ,
I have this doc. Could you confirm there are no changes in the interfaces? So we can just replace 7.6.2 libraries with 7.7 and that's all we need to do?
Hello @igorg
The RFA team confirms that you do not need a code change when upgrading from RFA C++ 7.6.2 to 7.7, you can just replace the libraries.
Please note that I still suggest you re-test the application before deployment to the Production environment.
Hello @igorg
I will verify with the RFA team and give you more updates.
