Added Decimal places when using OMMConsumer Post
We have just switched from RFA/MarketlinkIP to EMA/Contributions Channel and when contributing to 2 decimal places of precision we are now seeing 4 decimal places shown on Elektron. Can we restrict the precision back to 2 decimal places?
elektronrefinitiv-realtimeelektron-sdkrrtema-apijavapostingcontributions
Hi @peter.morris
Can you please confirm which version of EMA you are using and the language version too?
I just tried the following values with a recent EMA Java version (EMA Java 3.6.0)
and if I post the following values to a RCC test RIC:
int _bid = 3400, _ask = 3410;
using:
FieldList nestedFieldList = EmaFactory.createFieldList();
nestedFieldList.add(EmaFactory.createFieldEntry().real(22, _bid++, OmmReal.MagnitudeType.EXPONENT_NEG_2));
nestedFieldList.add(EmaFactory.createFieldEntry().real(25, _ask++, OmmReal.MagnitudeType.EXPONENT_NEG_2));
I see the following:
If, however, I use int _bid = 340000, _ask = 341000 and EXPONENT_NEG_4, I see the following:
I have not tested with EMA C++, but I expect the same behaviour will manifest.
I viewed the above values in both Refinitiv workspace and a RFA Java Gui example.
Thank you @umer.nalla, this has fixed our issue. We are also using EMA Java 3.6.0.
