I'm trying to pull dividend announcement data through the eikon.get_data() function. I can pull ex-dividend dates but I'm not sure if there is functionality to pull the dividend announcement dates. I am using the following function:
start_date = '2021-06-01' end_date = '2021-06-03' instr, err = ek.get_data('0#.SPX','TR.IndexConstituentRIC') instr = instr['Constituent RIC'].tolist() # Remove duplicates, None and empty strings from the list instr = list(dict.fromkeys(instr)) instr = list(filter(None, instr)) instr = list(filter(str.strip, instr)) events_df, err = ek.get_data(instr,['TR.EventStartDate','TR.EventType','TR.EventTitle'], {'SDate':start_date, 'EDate':end_date, 'EventType':'EXDIV'}) events_df.rename(columns = {'Event Start Date':'Event Date'}, inplace = True) events_df = events_df[['Event Date','Instrument','Company Event Type','Event Title']] events_df['Event Date'] = pd.to_datetime(events_df['Event Date']) events_df.dropna(subset = ['Event Date'], inplace=True) events_df
The github resource (https://github.com/Refinitiv-API-Samples/Example.EikonAPI.Python.CompanyEvents/blob/master/CompanyEventsCalendar.ipynb) I was using did not list announcement date as one of the event types. Is it possible to pull this data down?
Ideally I would like the output in the "Event Name" column in Eikon, show below:
Thanks.
