Matching API Errors
Hi all
The following RICs get not identified with the record permid matching REST API:
Input file:
LocalID,Standard Identifier
1,RIC:IIP_u.TO
2,RIC:BIP_u.TO
3,RIC:WIRu.TO
4,RIC:URW.AS
5,RIC:CUF_u.TO
6,RIC:CRR_u.TO
7,RIC:KMP_u.TO
8,RIC:CAR_u.TO
9,RIC:BEI_u.TO
10,RIC:HNKG_p.DE
11,RIC:REI_u.TO
12,RIC:326030.KS
13,RIC:FCR_u.TO
14,RIC:CSH_u.TO
Output:
ProcessingStatus,Match OpenPermID,Common Name,Match Level,Match Ordinal,Original Row Number,Input_LocalID,Input_Standard Identifier
OK,,,No Match,,2,1,RIC:IIP_u.TO
OK,,,No Match,,3,2,RIC:BIP_u.TO
OK,,,No Match,,4,3,RIC:WIRu.TO
OK,,,No Match,,5,4,RIC:URW.AS
OK,,,No Match,,6,5,RIC:CUF_u.TO
OK,,,No Match,,7,6,RIC:CRR_u.TO
OK,,,No Match,,8,7,RIC:KMP_u.TO
OK,,,No Match,,9,8,RIC:CAR_u.TO
OK,,,No Match,,10,9,RIC:BEI_u.TO
OK,,,No Match,,11,10,RIC:HNKG_p.DE
OK,,,No Match,,12,11,RIC:REI_u.TO
OK,,,No Match,,13,12,RIC:326030.KS
OK,,,No Match,,14,13,RIC:FCR_u.TO
OK,,,No Match,,15,14,RIC:CSH_u.TO
Those should all be valid RICs, could you please have a loot?
Thanks and best
Simon
intelligent-tagging-apipermid-apiopen-permid-apiric
@simon.keel
It looks okay. I tested it several times.
quote="""
1,RIC:SESFd.PA
2,RIC:BEP_u.TO
3,RIC:BEI_u.TO
4,RIC:VOWG_p.DE
5,RIC:WIR_u.TO
6,RIC:KINDsdb.ST
7,RIC:CUF_u.TO
8,RIC:326030.KS
9,RIC:FCR_u.TO
10,RIC:DIR_u.TO
11,RIC:GRT_u.TO
12,RIC:BBU_u.TO
output,err = opid.match(quote,dataType="Quote", raw_output=False)
output
The output is:
@simon.keel
You are correct. From my test, it is unstable. It works sometimes. I will contact the Open PermID support team to verify it.
hi @jirapongse.phuriphanvichai
do you have an update on this issue? i still cannot verify the following RICs:
SESFd.PA
BEP_u.TO
BEI_u.TO
VOWG_p.DE
WIR_u.TO
KINDsdb.ST
CUF_u.TO
326030.KS
FCR_u.TO
DIR_u.TO
GRT_u.TO
BBU_u.TO
thanks and best
simon
thanks for the prompt reply @jirapongse.phuriphanvichai , must be an issue on my side then, will check!
